SIM900 With ARM
Dear friends,
I have a project where I need to read a string from a URL using SIM900 module and ARM microcontroller.
Looking into the manuals I found out that I need to use HTTP commands. Everything is fine, I only have one little problem. I do not have the actual UR, I just have the IP address of the URL(104.131.67.214). How ap I supposed to use it with AT+HTTPPARA?
is this correct?
AT+HTTPPARA = "URL","104.131.67.214"
best regards
  • What would a URL be if you use your ordinary web browser? Wouldn't you try http://104.131.67.214/ and see what happens? Is there really much difference if you only know an IP number, or if you only know ha site name? What do you actually think happens if you enter http://www.google.com in the address bar of a web browser?
  • Dear Per,
    I know that is the case. But I was not sure in the case of SIM900.
    That should work I guess.
    Thanks for your reply. I think I will go with what you said.
  • Just a note - it can matter for the web server if you know the actual host name or just an IP number.
    A single server can have multiple names, and host multiple web sites - and decide which web site to present based on which name you specified. There is a HTTP field in the request that informs the server about which host name you used when locating the server.
    The above is what makes it possible for a web hotel to handle a huge number of web sites without requiring a huge number of machines or a huge number of IP numbers - extra important because of the scarcity of public IPv4 addresses.
