LED with WS2812B and STM32F1?
I would like RGB LED chip WS2812B used as a signal LED and thus seeking what the easiest way over 1Wire bus WS2812B set basic colors with one or two LEDs.
This approach me for one LED comes complicated
mikrocontroller.bplaced.net/.../
A simple idea?
  • I've not done it on the STM32F1, but recently used SPI to drive one on an LPC812. Works great.
  • SPI is an interesting solution, but unfortunately requires two I / O and SPI clock is then wasted. But even so, thank you.
  • On the LPC812 it is possible to allocate just one pin for SPI use, so I used the data. Can you do that on the STM?
    Another solution I considered was using the UART and inverting the signal.
    Or, of course, you could consider bit-banging.
  • If you know at STM32F1 have the minimum configuration SPI two pin, clock and data.
    UART is possible configure as 1Wire transmit, unfortunately inverse UART for driving WS2812B need 7 bit UART mode 1start bit + 7 data bit + 1 stop bit = 9 bit, 24bit for W2812B *3bit ( 3UARTbit per one W2812B bit) 72/9 = 8byte per setting W2812B.
    STM32F1 have only 8 or 9bit mode (I thing).
  • All that just makes me glad I chose the LPC812 for these small projects. I did originally consider ST, but have been bitten with their sudden removal of products too many times.
  • It is trivial to bit-bang both I2C and SPI master, as long as the thread/main loop performing it can allow the additional time it takes.
    But prio 1 when selecting a processor is to first have figured out all needs and select a processor that well fits the requirements. Saving $0.30 on a too small processor tends to come back and haunt.
    The WS2812B is neither I2C nor SPI; but with SPI being so versatile, it can be used quite admirably with this device (with a couple of minor gotchas).
    One point concerning the device that is worth noting. There are a number of articles concerning the required high accuracy of timing kicking around the internet. There are relatively few which mention that the timing is really not as tight as a reader might first think. I've found a few of the latter ones to to be quite persuasive in their reasoning and well worth considering.
    It is a frequent requirement to first take a processor one is familiar with and experimenting with external devices that are being considered for a project. Hence my mention of the LPC812. I find it great for finding my way around the ever increasing number of boards now freely (and cheaply) available on line. Then, having better knowledge of what is really required I can go on the hunt for the most suitable real processor.
  • This specific protocol is fast for using interrupts for each I/O pin toggle. But it is still so slow that it isn't fun to turn off interrupts while busy-waiting - especially when the number of chained LED:s is high, since all bits has to be sent out in a sequence to control the last LED in the chain.
    So SPI with FIFO or DMA would be the optimal hardware-acceleration. SPI is lovely to hardware-accelerate a number of serial protocols.
  • SPI is lovely to hardware-accelerate a number of serial protocols.
    At the risk of making this thread sound like an SPI love-fest, I have to say that I totally agree.
  • Hello
    is it the same for the ws2813 leds?
    www.led-color.com/.../WS2813 LED.pdf
    I am not sure the ws2813 could share the same controlling code as ws2812!!
