I need to move to RTX5 And I think I have it set up right based on the migration notes. My code in app_main never runs?
void app_main (void const *argument) { //this code never runs uint8_t buf[2]; USBD_Initialize(0); /* USB Device 0 Initialization */ USBD_Connect (0); /* USB Device 0 Connect */ //init OBDGenie device = getDevice(); device->init(); device->probeForGW(); while (1) //usb loop { device->setData(); } } osThreadDef(app_main, osPriorityNormal, 1, 0); int main (void) { HAL_Init(); /* Initialize the HAL Library */ SystemClock_Config(); /* Configure the System Clock */ SystemCoreClockUpdate(); // Update system clock4 osKernelInitialize(); osThreadCreate(osThread(app_main), NULL); osKernelStart(); for (;;); }
[/pre]
It seems that you have an STM32 device.
Try to debug your application and check which “os” function fails (inspecting return value) and where your program ends up.
Most likely the ST template code or CubeMX generated code conflicts with RTX.
Make sure that you don’t override any of the 3 exception handlers used by RTX (SysTick, PendSV and SVC).
Also ensure that the NVIC Priority Grouping and Interrupt Priority of SysTick, PendSV and SVC is not changed (check HAL_Init function).
Yes stm32f205
Using debug the code does step normal until I hit
USBD_Initialize(0);
but this is proprietary code so I have no way to debug it.
You initially stated that code in app_main never runs and my previous comments focused on that.
However after debugging you confirmed that app_main is executed until “USBD_Initialize” is called.
What happens when USBD_Initizalize is called?
If the function returns then check the return value. www.keil.com/.../group__usbd__core_functions__api.html
Correct, I'm not sure what changed this though, the debug was having issue yesterday. I'm not sure how to troubleshoot this USBD_Initialize code. If i hit f10 or f11 it does not step. If I add
int y; y=USBD_Initialize(0);
y is never in scope.
From what I know, this code is not exposed so there is no way to step in to it.
Define the variable as global and add ‘volatile’ so that it does not get optimized (also decrease optimization level if needed).
If you are still not able to see the return value then go to disassembly (look for something like “BL.W USBD_Initialize”) and step over that call. After that the return value is in register R0.
That helped, looks like a USB stack size issue with the migration.
