Hi, I'd like to use source insight to edit from keil's uVision.
What is the fairy common way to migration to the Source Insight from KEIL's uVision?
This is Keil's forum for Keil products: http://www.keil.com/forum/
For support on Source Insight, see www.sourceinsight.com/.../
With "Understand C" I usually just point it at the root of the project tree, and then add include paths as prompted.
Do you not have people locally who can walk you through the tools you have chosen?
