Turn On a LED on STM32F4-discovery
Hi everyone,
I want to turn on a LED on my STM32F4-discovery board
Here is the code :
int main()
// Enable the GPIO Clock
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
// GPIO Configuration
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_14; // Led 6 Blue selected
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; // Mod out !
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; // 50 MHZ clock frequency
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; // Push pull mod
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP; // Pull up
GPIO_Init(GPIOD, &GPIO_InitStruct);
// Turn on the LED
GPIO_SetBits(GPIOD, GPIO_Pin_14);
return 0;
I'm using uvision 5.13.0.0
It compiles and flash succesfully but nothing happen after. I don't know what is wrong with this. I also tried with this :
STM_EVAL_LEDInit(LED6);
STM_EVAL_LEDOn(LED6);
but there is no worked.
Can you help me ?
Many thanks :)
  • First thing is that you're falling out of main.
    Put in something like:
    void main (void)
      // do stuff
      while (1)
  • Thanks for your help.
    I change line "return 0;" by "while(1);" but it had change nothing. Any other idea ?
  • Try Troubleshooting using the System Viewer. I would look at RCC and GPIOD to see if
    the Registers appear to be properly set up.
  • Or heaven forbid, use the debugger, and have the while loop alternately drive the led high and low, and step through the code to confirm it's actually being run.
    The code looks Ok.
  • Hi guys,
    I launched a debug session for this code :
    int main()
            // Enable the GPIOD Clock
            // GPIOD Configuration
            GPIO_InitStruct.GPIO_Pin                = GPIO_Pin_15;                  // Led 6 Blue selected
            GPIO_InitStruct.GPIO_Mode       = GPIO_Mode_AF;                 // Mod out !
            // GPIOD-PIN 15 ON
            while(1)
                    GPIO_SetBits(GPIOD, GPIO_Pin_15) ;
    Here is the result of debug session :
        12:         // GPIOD Configuration
        13:         GPIO_InitTypeDef GPIO_InitStruct;
    0x080004E2 2101      MOVS          r1,#0x01
    0x080004E4 2008      MOVS          r0,#0x08
    0x080004E6 F7FFFF3D  BL.W          RCC_AHB1PeriphClockCmd (0x08000364)
        14:         GPIO_InitStruct.GPIO_Pin               = GPIO_Pin_15;                         // Led 6 Blue selected
    0x080004EA F44F4080  MOV           r0,#0x4000
    0x080004EE 9000      STR           r0,[sp,#0x00]
        15:         GPIO_InitStruct.GPIO_Mode       = GPIO_Mode_AF;                     // Mod out !
    0x080004F0 2002      MOVS          r0,#0x02
    0x080004F2 F88D0004  STRB          r0,[sp,#0x04]
        16:         GPIO_InitStruct.GPIO_Speed      = GPIO_Speed_50MHz;  // 50 MHZ clock frequency
    0x080004F6 F88D0005  STRB          r0,[sp,#0x05]
        17:         GPIO_InitStruct.GPIO_OType      = GPIO_OType_PP;          // Push pull mod
    0x080004FA 2000      MOVS          r0,#0x00
    0x080004FC F88D0006  STRB          r0,[sp,#0x06]
        18:         GPIO_InitStruct.GPIO_PuPd       = GPIO_PuPd_UP;                     // Pull up
        19:
    0x08000500 2001      MOVS          r0,#0x01
    0x08000502 F88D0007  STRB          r0,[sp,#0x07]
        20:         GPIO_Init(GPIOD, &GPIO_InitStruct);
        21:
        22:         // GPIOD-PIN 15 ON
    0x08000506 4669      MOV           r1,sp
    0x08000508 4804      LDR           r0,[pc,#16]  ; @0x0800051C
    0x0800050A F7FFFEDB  BL.W          GPIO_Init (0x080002C4)
        23:         while(1)
        24:         {
    0x0800050E E004      B             0x0800051A
        25:                 GPIO_SetBits(GPIOD, GPIO_Pin_15) ;
    0x08000510 F44F4180  MOV           r1,#0x4000
    0x08000514 4801      LDR           r0,[pc,#4]  ; @0x0800051C
    0x08000516 F7FFFF1D  BL.W          GPIO_SetBits (0x08000354)
    0x0800051A E7F9      B             0x08000510
    0x0800051C 0C00      DCW           0x0C00
    0x0800051E 4002      DCW           0x4002
    0x08000520 F04F7040  MOV           r0,#0x3000000
    0x08000524 EEE10A10  VMSR           FPSCR, r0
    0x08000528 4770      BX            lr
    0x0800052A 0000      MOVS          r0,r0
    0x0800052C 053C      DCW           0x053C
    0x0800052E 0800      DCW           0x0800
    0x08000530 0000      DCW           0x0000
    0x08000532 2000      DCW           0x2000
    0x08000534 0660      DCW           0x0660
    0x08000536 0000      DCW           0x0000
    0x08000538 01C4      DCW           0x01C4
    0x0800053A 0800      DCW           0x0800
    0x0800053C FFFFFFFF  DCD           0xFFFFFFFF
    0x08000540 FFFFFFFF  DCD           0xFFFFFFFF
    I wonder if my homemade base project is well configured. Maybe the uC isn't well init.
  • I think there is also some code before main in the start up file that will be performed
    to set up the clocks. That is why I suggested that you use system viewer to look at the RCC.
    Can you right click on the project so you can get to project options and the debug tab.
    and the Unclick the run to main checkbox. then run debug. choose to single step into the code.
    What function does the debugger go to. Does it go into a function probably called system_init.
    This is where it would initialize the clock stuff. this code is before the main function in another file that is assembly code.
    also can you find a function to clear the led.
    Hope this helps
  • I launched a debug session with your advises and it runs until System init function like you said.
    175:                  LDR     R0, =SystemInit
    0x0800020C 4809      LDR           r0,[pc,#36]  ; @0x08000234
    Then there is this code but i can't find a function to clear the LED :
      LDR     R0, =SystemInit
                     BLX     R0
                     LDR     R0, =__main
                     BX      R0
                     ENDP
    Then with the system viewer i checked some registers. In RCC, i checked AHB1ENR and nothing is activated. In GPIOD, i checked BSRR register and nothing is activated too. It seems that clocks are not well initialized. Do you know what i must change to correct it ?
    Many thanks !
  • One more thing that came to mind. Make sure you have the debug selected and not simulation. I think simulation might be the default mode. You should find the check box in the same place you unchecked run to main.
  • do some more single stepping and verify that the clock registers are really being written to.
  • Refer to this appnote http://www.keil.com/appnotes/docs/apnt_268.asp
    Even when it says Middleware, it is actually a good step-by-step introduction that is generic enough.
    This might help to: www2.keil.com/.../
  • Use something like this in your loop
            while(1)
                    GPIO_SetBits(GPIOD, GPIO_Pin_15); // Toggle the LED, so you can see it change as you step each function
                    GPIO_ResetBits(GPIOD, GPIO_Pin_15); // this isn't magic just requires some thought
    Ok, we're getting really off in the weeds. When you use the debugger, does it get you to the first instruction of main(), OR NOT??
    If you hit STOP, where does it stop?
    If you uncheck "run to main", can you step over SystemInit, or does it crash?
    The code in __main sets up the C runtime environment and eventually calls your main() function.
    If SystemInit() is failing, you need to look at the source code in system_stm32f4xx.c and determine if it's doing something stupid, like setting the clocks wrong, or the PLL too high. The Discovery board uses an 8 MHz source clock, make sure your code is consistent with that, and the HSE_VALUE for the project is 8000000.
  • Hi,
    Fisrt i appologize, I'm a newbie and this is the fisrt time I use Keil and STM32.
    I checked with all your instructions and when i check "Run to main" option it crashes and i'm on this loop :
    void HardFault_Handler(void)
      /* Go to infinite loop when Hard Fault exception occurs */
      while (1)
    So i can't go in main.
    Then I unchecked "Run to main" option. SystemInit is ok and doesn't crash.
    In my project i have these options in preprocessor symbols definition:
     USE_STDPERIPH_DRIVER,STM32F4XX,KEIL_IDE,PLL_M=8,PLL_N=336,PLL_P=2,PLL_Q=7,HSE_VALUE=8000000
    Then it starts __main instruction and it seems to crash here. What can i do after that to check the error ?
    Many thanks,
  • When you call __main, lots of things will happen before you reach your normal main() function.
    You might get a stack overflow.
    Or maybe your memory layout doesn't match your chip, so the startup code tries to initialize non-existing memory.
    Maybe your project specifies external memory, and you haven't initialized the memory controller that interfaces with the external memory.
  • You might get a stack overflow.
    Or it could be that the stack pointer is initialized assuming that the stack resides in memory that is only available once __main is executed. With the execution of __main being a call, that execution occurs, only to fail when it attempts to return to the caller.
