Strange compilier's behaviour with function template, NAN and default parameter
I have got an error message with next code
template< typename Type >
int func( Type as, float fl=NAN );
error:  #109: expression preceding parentheses of apparent call must have (pointer-to-) function type
It seems the problem is with resolving NAN, defined in math.h at line 249
#   define NAN (__ESCAPE__(0f_7FC00000))
There is no problem if no NAN used
int func( Type as, float fl=0 );
There is no problem if template not used
int func( int as, float fl=NAN );
There is no problem with GCC.
Compilier version
*** Using Compiler 'V5.05 update 2 (build 169)'
  • Experiments:
    int func( Type as, float fl=(float)(NAN) );  //fail
    int func( Type as, float fl=0f_7FC00000 );  // Compiled. No error
    int func( Type as, float fl=__ESCAPE__(0f_7FC00000) );  //fail
  • The problem appears to be that the C++ compiler does not recognize the (undocumented?) compiler intrinsic __ESCAPE__ early enough in the parsing process to decipher this expression.
  • I've found this thread about __ESCAPE__ http://www.keil.com/forum/9630/
    It seems problem may be solved with declaring
    #define __ESCAPE__(__x)  (__x)
    I will test soon.
  • That makes __ESCAPE into a null operation. But the question then is what functionality that gets lost - because ARM must have had some intention with the __ESCAPE() construct.
  • ARM must have had some intention with the __ESCAPE() construct.
    Evidently. But the only description of it that you'll find is very vague about what it actually does. They only tell it's a compiler builtin, and that it's used to hide usages of non-standard features from standard-picky modes of the compiler. I.e. they explain the why, but not the how.
    #define-ing it away is supposed to only be needed for compilers other than ARMCC using ARM's <math.h> or <limits.h>. Why one would do that is beyond my tolerance for utter nonsense. :->
    As it is, this is a failure of ARM's headers to play nice with ARM's compiler. In other words: this a compiler bug worth reporting to support.
  • Ah - so basically it already is a no-op.
    It's expected to be 100% transparent when compiling with the ARM compiler - just "unit expansion" of the argument(s).
    While it's expected to expand to nothing at all for "non-compliant" compilers.
    So with the ARM compiler:
    And with another compiler:
    int func( Type as, float fl= );
    But that would mean that the "=" should have been inside the __ESCAPE__, or the "non-compliant" compilers that doesn't support this 0f_7FC00000 hexadecimal floating-point value will still fail to compile.
    It feels like the __ESCAPE__ construct was a design that failed before it left the drawing board.
    Not quite. ARM wouldn't have to go this far out of their way just to create a no-op. Just writing nothing at all would have the same effect.
    No. With any other compiler, you get.
    int func( Type as, float fl= __ESCAPE__(0f_7FC00000) );
    What that actually turns into depends entirely on what the user of the alien compiler decides to #define __ESCAPE__ as to fix this obvious syntax error.
    But OTOH that alien compiler would surely come with its own <math.h>. So there should never be a need to pull in the one from ARMCC's system include file collection.
    Using another implementation's Standard C Library headers is a Bad Thing, and one should fully expect bad things to happen because of it. As I take it, this macro may be just an elaborate, circuitous way of expressing "Here Be Dragons".
  • So, does anybody have bright idea and better solution than
    #ifdef __CC_ARM
     #undef NAN
     #define NAN  (0f_7FC00000)
    #endif
    or even
    #ifdef __CC_ARM
     #undef __ESCAPE__
     #define __ESCAPE__
    #endif
    The only actual solution to this is for Keil/ARM to find.
    It's ARM's own header file, and ARM's own compiler, so if combining the two in a slightly unusual fashion causes a problem, that's ARM's problem to solve. So have you filed a support request yet?
    Until then, your best bet at a temporary workaround would probably be one of those you showed.
  • Yet another...
    #include <cmath>
    class Cla {
      float h = NAN;  // error:  #65: expected a ";"
    What's the f... The medicine is same
    #include <cmath>
    #ifdef __CC_ARM
     // ARM CC bug http://www.keil.com/forum/60227/
    #endif
    All files compiled with --cpp11.
