C166:XC2785
I write simple code for toggle PORT2.0 of xc2785 in keil simulator.
when i start the simulator,the IO port not toggled.
this is my IO port setting.
Some thing is wrong in the (Peripheral/IO-ports/port2)in simulator window.In this panel there is DP2 and ODP2 register but in datasheet there is not!!!
what is wrong?
thanks.
void init_port2()
  P2_IOCR00 = 0x80;// Push pull output
  P2_OUT = 0x0001;  // set P2.0 to high
  while (1)
    /* Toggle P2.0 */
    P2_OMRL = 0x0101;
    delay();
0
