I want to define the variable in the designated address space.I used another compiler,before the variable define,I can use the #pragma to distribute the address space. What can I do with Keil?Such as the #pragma! Thank you very much!
There are probably numerous ways, but this is one that I have used:
uint32_t __attribute__((section("MySection"),zero_init)) MyInt;
Thank you for your reply!but I also have some question: 1ã€I want to define the whole data in the designated address space one by one,such as #pragma section int data1; int data2; . . . the variable distribute the address automatic so,how can I do? 2ã€if use your way,where define "MySection",what is mean about the "zero_init"? Thank you very much again!
You can put the whole collection of items you want placed in a section within a structure. That also groups all the information into a logical unit.
The zero_init is used to force the linker to put the data into a section that is not initialized at startup, which is very useful for non volatile data. You might not need or want it.
Thank you very much! I define the section in the sct like this: RAM 0x20000000 0x7FFF { ADDER 0x7FFF { data_common.o(+RW) (foo) ; select section foo from data_common.o } }
define the variable in the data_common.c like this: #pragma arm section rwdata="foo" int data=0; #pragma arm section rwdata
but the variable address in the .map file not assigned to the correct address after compile: Base Addr Size Type Attr Idx E Section Name Object
0x1fff8000 0x0000000c Data RW 605 .data main.o 0x1fff800c 0x00000004 Data RW 647 foo data_common.o
can you help me?Thank you!
I can see no reason for me to continue to give advice when you have chosen to do something other than what I have suggested.
It's over to you now.
I have tested the way you told me like this,but it not effective: int__attribute__((section("foo"))) data;
define the section in the .sct like this :
RAM 0x20000000 0x7FFF { RAM_Data 0x20000000 0x7FFF { data_common.o(+RW) (foo) ; select section foo from data_common.o } }
but the address in the .map didn't in the expect address: data 0x1fff800c Data 4 data_common.o(foo)
so,if I define variable by this method,what can I do? Thank you very much!
