Could someone help me with the following:
mov a,#not 0x08
will simply place the value 0x08 into accumulator. The following however does not work and I would like to know why:
bit_mask equ 0x08
mov a,#not #bit_mask
The reason it does not work has to do with the #not.
I make extensive use of bit flags stored externally in xram. To set one of these flags is relatively simple using orl a,#bit_flag_mask. But to clear the flag I would have liked to use anl a,#not #bit_flag_mask. Instead I have to do the following:
mov a,#bit_flag_mask cpl a mov b,a movx a,@dptr anl a,b movx @dptr,a
Thank you in advance Joe
