I am migrating project from Keil version 5.14 to 5.23. I have below doubts regarding version 5.23: 1. Does 5.23 support task and its functions or it supports only thread ? 2. In version 5.14 there are functions like task_lock , task_unlock which are not available in 5.23. Which similar functions are present in 5.23?
Below are details of components and its variant used in KEIL MDK version 5.23: CMSIS core : 5.0.1 RTOS : 1.0.0 ARM compiler: 1.2.0
Request to reply as early as possible.
Regards, Snehal.
1. Task and thread are just different terms referring to the same. 2. osKernelLock/osKernelUnlock
More information is available here: http://www.keil.com/pack/doc/CMSIS/RTOS2/html/index.html
hi,
Thanks for reply.. Can RTOS2 API be used with mbedTLS library, as library files have cmsis_os.h included in them. and RTOS2 have cmsis_os2.h.
Request to reply...
Should be possible.
RTOS2 provides also a compatibility module for RTOS1 (cmsis_os.h).
Take a look at the migration guide: http://www.keil.com/pack/doc/CMSIS/RTOS2/html/os2Migration.html
