C251 Compiler options for memory banking
I am struggling with getting the compiler set up correctly and was wondering if anyone could please help.
Our circuit uses an external flash memory configured for paging. All I am trying to do is get the blinky example code to run. I have compiled it sucessfully, no errors or warnings and I have compared the machine code output with what is in the flash buffer and it corrolates ok, but when I put the chip in the board it doesn't run the code.
The same code copied into a project created by a previous engineer works fine, but I need to start a new project and don't seem to be able to get this to work.
0
