Dear all, I'm experimenting Keil Configuration Wizard and it looks fine. Apart from number (<o>) and string (<s>), is it possible to enter "free text"? This could be usefull, for example, to setup a field with a macro name, a callback function name, etc. For example, I'd like to enter something like the following:
#define TRUE 1 #define FALSE 0 /* // <<< Use Configuration Wizard in Context Menu >>> // <e0> Configuration wizard example // <o1> Integer data <1-100> // <s0> String data // </e> // <<< end of configuration section >>> */ #define MODULE_ENABLE 1 #define MODULE_INTEGER 1 #define MODULE_STRING "MyString" #define I_NEED_THIS TRUE #define I_NEED_ALSO_THIS MyCallback
Is it possible to properly show and manage also "I_NEED_THIS" and "I_NEED_ALSO_THIS" values? Thank you in advance for your reply. BR
The Configuration Wizard Annotations are summarized at: http://www.keil.com/support/man/docs/uv4/uv4_ut_configwizard.htm www.keil.com/.../_config_wizard.html
Thank you Mr. Kopsch for your reply. I've taken a look to the documentation, but I don't find a definitive answer to my question. I suppose a tag to enter free text is not supported yet. So, the correct question for Keil guys is: do you plan to implement this tag or something similar?
I'm sorry - confirmed by our management such extensions are not planned.
