The RTX RTOS provides users a configuration UI to configure RTOS parameters. In the configuration UI, there is a item called "Number of concurrent user threads" under "Thread configuration".
What does this item mean ? The keil explains that it means: Indicates the maximum number of threads that will run at the same time (including main).
Does it count timer and idle thread ?
thanks.
Thanks for your explanation.
