Dear friend,
I need to set up a project with emwin on LPC1788. I have downloaded the sample emwin file from NXP website, but I cannot make it work. I have customized most of the part I am aware are required. But GUI_Init() does not work. The following functions in the GUIConfig.c are executed properly:
void GUI_X_Config(void) { // // Assign memory to emWin // GUI_ALLOC_AssignMemory(_aMemory, GUI_NUMBYTES); GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE); }
according to emwin user manual the next function that should be called is:
LCD_X_Config()
when I set a breakpoint on this function, the execution does not reach here. There must be something between calling these two functions that causes the problem. I do not have access to the source code so I do not know what it is.
Has anybody had the same problem? Please help me.
Best regards
