Hi, Am new to keil software ,in my current project the debugging interface is Keil uv3/uv4, i tried to find keil uv3 but i didnt get any links to download the software ,so now am using uv5 at this http://www.keil.com/download/, but even if i use this the program is not getting built.Am using FCM8531 and .can anyone pl tell where i can find keil uv3. Thanks in advance
Note that uVision is just the GUI - it is, essentially, separate from the actual build tools - compiler, assembler, linker, etc.
If you're having troubles building, then it's almost certainly the version of those build tools that is the important thing.
Note that uVision-3 is long obsolete and was discontinued years ago.
If you had a licensed copy, you could try asking Keil nicely if they will do you a favour and provide you with a legacy copy...
Contact details are at the bottom of every page of this site
