Library Path to sysctl.h
I'd like to include sysctl.h to use SysCtlClockSet(). I get a file not found error. The only reference to this file I've found in the Kiel_v4 installation is in the C:\Keil_v4\ARM\RV31\LIB\Luminary\driverlib directory. My target device is a TM4C123GXL. Is this the correct directory, or do I need to install other libraries?
If it is the correct file how do I set the path to it?
