Hi, I'm using LPC4088 (Cortex M4) and I need to swap uint32_t on the bit level. I have a chip that transfer data 32bits (with SSP) with Lsb first - so I have to swap the result in my code. Because I do it very often - I need the fastest algorithem to do that.
1. The easy way its to shift 32 times and create a new variable depend on the lsb bits. 2. Another technic is to handle the uint32 as 4 bytes (8 bit) and to use lookup table for each byte to swap it. This technic read first byte - swap it (with lookup table) and put in the new location (at the msb side) - and continue for all 4 byte.
Maybe there is a faster technic - (ASM, C..)
Any better solution? Doron
REV... Intrinsics? __REV(), REV16(), __REVSH(), ...
Unroll as required..
__asm u32 revbit(u32 data) { rbit r0, r0 bx lr }
The REV works on a byte level - Change from big endian to little endian. I Need a bit level solution..
Pier, I Think we have a winner.. It's looks perfect - many thanks Doron
