Hello, I try some like this: xdata const char table[]={"BBBB"}; to place consts in ext. ROM. Everything is OK, but i get only ONE hex file. I need hex file to burn internal flash ROM in 89s8252, and another hex to burn external data rom. How can i make two hex file from OMF2 file? Is this possible?... Tomasz Halat
With the code you have posted the table will be stored in code space then loaded into xdata at runtime. If this is not what you want you could create a binary image of what you want in the external ROM by whatever means (utility program, hex editor etc) then use bin2hex to convert to hex file. Stefan
specify code to have it placed in CODE space. Have you looked at XCONST?
Hello, I need to place code into code memomory, and constans into external ROM. When i use #pragma STRING (XDATA) #pragma XCROM then all strings i "xdata const" data should be placed into external ROM. I've got HEX with CODE, but I have no HEX with strings and datas. That is my problem. Best regards, Tomasz
You need to use OHX51 - but look out for the bug in some versions: http://www.keil.com/forum/docs/thread2074.asp The version shipped with the latest C51 download (v7.07) still has this bug - you will have to request the fixed version from Keil. Also, have a look at this thread: http://www.keil.com/forum/docs/thread2636.asp
Hello, Thanks so lot. I've got two hex files now! :)
