In my C source files, I want my keywords to show up in bold and my normal text to be, well, normal. But if I click the "bold" box for keywords, the bold setting is applied to all text types! Grrr.... Is there any way to get around this? Registry settings? .ini settings? This isn't a huge deal but it's annoying enough. Thanks!
Is there any way to get around this? yes, buy a real editor e.g. CodeWright. I Hate IDEs where all components must be from the same place, why not can one not combine an editor from people that know how to make an editor (such as CodeWright) with a compiler from people that know how to make a compiler (such as Keil). I work with a patchwork combo of the two above. Erik
you can do it in Keil uVision . when you select "blod", do not forget to select the actived target in the upper box. if you want set you c keywords in blod only select : "edit C files " and "keywords"
