I bought some Silicon Labs C8051 boards, equipment, and PC for someone recently and am going through a computer now. I found some SW - created by Silicon Labs for the C8051F340 board I'm playing with now. It doesn't look like the guy ever compiled any of this code.
There is a Keil uVision3 compiler installed - version 3.50 it says. In several of the source code directories I find files that I suspect are for the Keil compiler/IDE perhaps.
They have extensions of .wsp and .omf. I've tried to run the uVision IDE and open these files - but it doesn't seem to work with them.
Does uVision3 create or use files with these extensions, as a project file of some sort, and if so, how do I open them ?
Note that uVision-3 is very old indeed - long obsolete.
So what is your goal here? Is this a load of "surplus" that you've acquired off ebay, or something?
Pretty sure uVision-3 didn't use .wsp - maybe some sort of "workspace" file for some other IDE? Maybe ask on the SiLabs forum? (don't forget to link your threads)
http://www.keil.com/support/docs/1774.htm
.omf would be an OMF file:
http://www.keil.com/support/docs/93.htm
http://www.keil.com/forum/11929/omf-records/
first, re SiLabs 'canned' code you will be better off here community.silabs.com/.../Forum second the SiLabs 'canned' code rely VERY heavy on macros, which are automatically included if you use the SiLabs software third, with the SiLabs software you get a brand new unrestricted Keui. (OK restricted as in can only be used with SiLabs chips)
Just out of interest: how do they enforce that?
The license number of course <doh>
That would restrict use of a particular installation of the software - but would not stop you using the generated code in other target devices ...
Of course. Nothing unusual about that.
So back to my question, then: How do they enforce that you can only use it for SiLabs chips ?
It's the only for SiLabs chips bit that I'm asking about.
Let's try again:
What part don't you comprehend???
The license number can restrict what options you have for the project. Same as it can restricts middleware features. It's hardly rocket science!
Same as www2.keil.com/.../mdk
Seriously, there are ways to circumvent many protection schemes.
So they'll probably come around and slap your wrist if you break the license agreement by being too much of a know-it-all smarty pants.
My point is that 8051 opcodes are 8051 opcodes - they are not specific to SiLabs.
So how can they restrict you to only loading those opcodes onto an SiLabs 8051 chip and not a Brand-X 8051 chip?
Other than, of course, simply relying upon you to abide by the licence terms.
Well done, I think you've understood it.
Like a lot of these things, it relies on a mixture of pig ignorance and trust.
My goal was compiling SiLabs sample code and programming the board. After some practice I was able to get it done - using the Keil compiler I got in the Silabs IDE I downloaded.
I got all this through a friend.
All set.
