Function "strlen()" work like "sizeof()" within Evaluation Kit
While I am working with the Evaluation Kit (contains an old Version of C51), I used
"strlen()" within a function, where the string in referenced using a pointer. The result is always 2 or 3; which is the size of the pointer variable. Now I guess,
"strlen()" simple consist of a "sizeof()" sourcecode.
Example:
// String + size
char stringbuffer[] = "Hello\0";
int string_length1;
// Correct Value
string_length1 = strlen( stringbuffer );
// Function Call
wrong_function( stringbuffer );
// Function
wrong_function( char* stringpointer )
int length_string2;
// wrong value
length_string2 = strlen( stringpointer );
0
