Hello, Does anyone know if there is a way to set project path macro?
For example when I use standard makefile I can quickly change library of all C files in project like this:
#USED_SDK := ../SDK_1 USED_SDK := ../SDK_2 SRC_FILES = $(USED_SDK)/file_A.c) SRC_FILES += $(USED_SDK)/file_B.c)
But with Keil project any time I update SDK version I have to change manually path to all files... :(
