Problems with filesystem
I am trying to use the filesystem with a NOR flash (AT45DB641E) on SPI1. I have all the middleware pulled in okay, but I cannot find where to tell it to use SPI1. It uses SPI0 by default, which is conflicting with stuff I already have on SPI0, hence the need to get it onto SPI1. Also I can't see where the SPI speed is set either.
I have tried setting "#define DRIVER_SPI_NUM 1", but this seems to be ignored (probably too late by the time it reaches that header file).
I am using finit to initialise it all. (Maybe I need to also call "SPIdrv->Initialize" or something??)
I'm guessing I missed something pretty basic. (This is the first time I have really used Keil middleware).
So, really my questions are:
1) How can I get the filesystem to use SPI1, instead of SPI0?
2) How do I set the SPI1 speed?
