New to this software, need some help. My code is right and all the rebuild thing goes smoothly, but when it comes to debug, it says cannot load the .axf file. I've tried to select folder in the output option for Target but I can't find any .axf file in all the files. How can I fix this problem? Thx a lot. I use ULINK2 debugger and the device is MK64FX512xxx12.
With this few information provided I recommend to compare your settings with one of Keils MK64FX512xxx12 example projects, offered by the PackInstaller
