Hi, I use Keil MDK-ARM 5.21 and Github.
While working with Keil, I have controlled codes using Git v2.10 and SourceTree (Git client).
Without using SourceTree, I wish to push or diff codes with Keil MDK. Is this possible?
For instance, when using Eclipse, the user can commit or push codes with the IDE.
You can check the below video to see what I mean.
youtu.be/BH4OqYHoHC0
Similarly, can the Keil MDK-ARM push/commit/diff without using extra Git clients?
-Best Regards
http://www.keil.com/support/man/docs/uv4/uv4_dg_sccmanager.htm
