Hello, We have used Keil development only since few days that problems already occur. In fact, we first tested Keil with simple examples proposed with the software (Helloworld, Traffic ...). Then it was just in simulation/emulation mode. But we wanted to go further in using our development board which is the Ertec EVA167. The microcontroller used is the Infineon C167CR-LM. The connection is made by RS232. The message that uVision sends to us is " Connection to target system lost ". We do not understand why. In fact, we are trying to send the source code by the Bootstrap way. We tested a lot of different configurations to try to solve our problem but it doesn't work. Thanks for your responses.
Hello Arnaud, in fact, I don't think that your problem can be solved easily. I think that the documentation of Keil Software (Chapter 11)is not very clear. I am not experimented enough to answer to your problem and I hope that someone will help you to find a solution soon. Best regards. Youss'
Hi Arnaud, do you mean with bootstraploader way, that you try to send a code more than 32 byte ? In this way I would recommend you to read the description of bootstraploader, since you need a second loader program. If this is the case (2nd loader stage program is available) first try to program with memtool, you can get at Infineon's homepage under 16-bit Micros --> application notes. This tool works fine and can program nearly all 16-bit Micros from Infineon. Hope this helps Stefan
