I have tried to write a simple embedded c program in keil for that purpose i added Startup.a51 file when i tried to compile it it had shown the warnigs
Build target 'Target 1' linking... *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_START MODULE: .\Objects\STARTUP.obj (?C_STARTUP) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_START MODULE: .\Objects\STARTUP.obj (?C_STARTUP) ADDRESS: 080AH Program Size: data=9.0 xdata=0 code=15 ".\Objects\loc" - 0 Error(s), 2 Warning(s). Build Time Elapsed: 00:00:00
what ever the program i change the warning remains same could you please help me in resolving it
do you have a main()?
You haven't enabled the SRC option for all your .c files, have you ... ?
http://www.keil.com/forum/14227/
yes i have main and mine is a simple progra and it is #include <reg51.h> void main(void) { unsigned char mynum[]=“ABCDEF”; unsigned char z; for (z=0;z<=6;z++) P1=mynum[z]; }
you need some code in main(). e.g. while(1); will do
i tried so and even i write code in assembly the same warning araises
You didn't answer that question!
start with this
void main (void) { while (1) {} // Spin forever }
and then add your stuff to see what makes it fail
Did you add the source file that contains the main function to the project?
See: http://www.keil.com/product/brochures/uv4.pdf - Chapter 6. Creating Embedded Programs. Page 79 explains how to add a source file.
