Hi all I use LPC17xx and would like to add QEI module in my code. can you give me example code or project which is using QEI in RTX OS or without RTX?
It looks like nobody pick-up that yet. This is because you might have been to short in the explanation of your problem.
You can actually find some QEI example at mbed.org. developer.mbed.org/.../QEI
mbed projects can be exported to MDK as explained here: developer.mbed.org/.../Exporting-to-uVision
This may give you a starting point for your project.
For device-specific resources, the manufacturer's website should be your first port of call:
www.nxp.com/.../
http://www.lpcware.com/
Thank you so much
