I am using ARM LPC2148 micro-controller to read data from MMA7361L accelerometer which is installed on a motor and wants to send this data to PC through Serial port. Then IN PC my MATLAB Code will perform the time and frequency domain analysis. But i am not able to write the correct required program for lpc2148 in C to read the data from mma7361l and to sent the same to PC in desired format for generating time and frequency plot as brifed above. request assistance
"i am not able to write the correct required program for lpc2148 in C"
Why not?
What have you tried?
Where are you stuck?
"request assistance"
What assistance, exactly, do you need?
A training course in 'C' programming?
A training course in general microcontroller interfacing?
A training course on the lpc2148 specifically?
A training course on the MMA7361L specifically?
A contractor to do this for you?
a contractor to do this for me.
Basically a contractor for me who can write this code and in which all the basic corrections like calibrating MEMS MMA7361L, Correction for 0g offset and final conversion of accelerometer output(which will be in milli volts) into acceleration (which will be in g). In addition any other correction or modification which will be required to have correct and accurate data at the PC so that my final time and frequency domain plots(which will be generated using MATLAB) are correct
Then you surely know how to find one. This forum hardly seems to be the correct place!
And if you are really serious, change the title to 'Looking for contractor'.
sorry its nothing like that, but yes i need help in c programming.
Arrogance or ignorance won't take you anywhere. Coming back to topic, what help do you need? What have you tried? Can you post any snippet/circuit you have done. Just doing a google search for your accelerometer shows a lot of code examples(mostly arduino). www.catb.org/.../smart-questions.html
