Dear All,
I have encountered a problem in simulating the following code on MDK-Lite Keil version 4.74.022. The ISR routine is not being executed during simulation with Keil V4.74 evaluation version only. This code runs on hardware and on Keil V3.36 simulator. I don't know what may be wrong with my MDK-Lite Keil version 4.74.022, maybe start-up file, but still don't know how to fix it.
Thanks for your help.
#include <LPC21xx.h> #define LED (1<<0) void Trigger_EXT_Int(void) __irq { if( (LED & IOPIN0) == LED) { //checking the state of the pin IOCLR0=LED; } else { IOSET0=LED; } EXTINT=LED; //CLEAR EXTENAL FLAG FOR EXTINT EGISTER VICVectAddr=0x00; } int main(void) { PINSEL0=0x0000000C; //set P0.1 as external interrupt PINSEL1=0x00000000; IODIR0=0xFFFD; //set as output P0.0 EXTMODE=0x01 ; //edge sensitive is selected in EINT0 pin; EXTPOLAR=0x0 ; //active on negative edge on P0.1 VICIntSelect=0; //CLASSIFIES INTERRUPTS AS EITHER FIQ or IRQ.Put a 1 for FIQ or 0 for IRQ. VICVectCntl0=14 | 32; //channel 14 is for ext int| enable bit 5 VICIntEnable=0x00004000 ; VICVectAddr0= (unsigned long)Trigger_EXT_Int ; IOCLR0=LED; while(1); }
Just a note here - you think it smart to assign the ISR function _after_ you have enabled the interrupt? What do you think happens if the interrupt is already pending when you enable it?
Applied your recommendation but Still issue is present.
Interrupts are not being simulated. In practice the software works, but in simulation does not work.
Regards, Clive
Problem Solved after configuring Linker settings.
