NMI implementation issue
I have written the NMI handler for the LPC1768 MCU based target board as below and I am using Keil MDK Lite v4.5. The CPU control enters the NMI handler when invoked by a logic High signal injected to P2.10 but, the issue is upon exit the CPU control loops in the HardFault_Handler implemented in the startup_LPC17xx.s file. Stack memory is set for 100 bytes. Also,is it possible to simulate NMI implementation in Keil MDK v4.5, i have tried it but no success.
void NMI_Handler (void){
LPC_GPIO1->FIOPIN |= (1<<29);
delay();
LPC_GPIO1->FIOPIN &= ~(1<<29);
int main (){
//Configuring GPIO P1.29 as Output to which an LED is interfaced
LPC_PINCON->PINSEL3 &= ~((1<<27)|(1<<26));
LPC_GPIO1->FIODIR |= (1<<29);
//Configuring P2.10 as NMI pin
LPC_PINCON->PINSEL4 &= ~(1<<20);
LPC_PINCON->PINSEL4 |= (1<<21);
//Enable NMI
NVIC_EnableIRQ(NonMaskableInt_IRQn);
while(1);
  • This is my attempt to answer the question
    I believe your NMI Handler will drop through and hit the next instruction that is
    the Hard Fault.
    looking at a startup file
    __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler
    you would drop through the function and then hit the HardFault Handler address since there
    is no branch in the C Function.
    Still I think your function was supposed to do a context switch at the beginning to
    save of some of the registers so they do not get corrupted be the handler. and then
    when the handler leaves it is supposed to restore the registers and branch to the address
    pointed to by the saved link register.
  • No, I'm pretty sure it saves context. This is a Cortex-M3. The LR will contain a magic value, and context in registers used by C stacked. LR would only need preserving further if you called some other subroutines, which doesn't seem to be the case.
    What would be illustrative is what the processor indicates the faulting condition is when it enters the Hard Fault Handler. The registers, stack, and instruction it faulted on. This will be significantly more enlightening than spinning in a while(1); wondering what happened.
  • You have Hard Fault. NMI priority is higher then Hard Fault priority and this is why you have Hard Fault only after NMI. Look like something happens in your delay function. Try comment code inside NMI_Handler and see what happens.
    //LPC_GPIO1->FIOPIN |= (1<<29);
    //delay();
    //LPC_GPIO1->FIOPIN &= ~(1<<29);
    Also, even if you have Hard Fault exception you should still have NMI working. NMI is HIGHER priority (except Reset).
  • The problem is with the following statement
    I suspected that this CMSIS API was for MCU peripheral interrupt enablement/disablement and not for NMI. Commenting this statement resolved the issue.
  • Remember that an enable command need not be responsible for a failure - if it enables broken code it will be the broken code that will hurt. And there are also often a number of setup steps needed before an "enable" is allowed.
