Change between thumb and arm state in C Code
I am trying to run some old code from Insiders Guide written in 2004. The code contained
__arm and __thumb inside the functions to indicate to the compiler the function types either
arm or thumb. After some searching I removed the __arm and __thumb from the functions and
tried to put before the functions #pragma arm and #pragma thumb before the functions.
These changes cause different errors by the compiler. Stating that the symbols are now
obsolete. How do I handle thumb and arm interworking in C Code.
Thanks for the help
  • There was a Thumb.C file and a Main.c file. I noticed it was saying that the thumb function
    was multiply defined. so I removed the thumb.c function since it looks redundant. In main.c
    there is a thumb function already defined. The errors went away. Still though does not look
    like it works correctly since some breakpoints are not being hit.
  • It is working now. after removing the extra thumb.c, the only change I remember making to get it to start working is selecting use memory layout from target dialog checkbox.
