How to convert .wav file into .hex file?
I want to use .wav files for sound generation. In order write those hex files on eeprom using eeprom programmer I want to convert those .wav files(Containing only RAW data and header is removed)into .hex files. Is there any utility available to do so?
  • This has already been answered in your existing thread:
    www.avrfreaks.net/.../about-converting-wav-file-hex-file
    The reason that thread is "stalled" is because it's awaiting clarification from you - simply re-posting the same question to restart the same discussion from scratch isn't going to help...
  • And you can't write a simple C application to read a binary file, strip the header, and output data in a basic hex format?
  • The header is normally so short that a number of people just ignore it and play the header too just pretending that it contains valid sound data. A few random sound samples before the real sound can often not be heard.
    That's ridiculous. (And exceptionally lazy.)
  • If you have a Linux machine with the sound device set up for correct number of channels + bits/sample + samples/second you can try to play wav files by just copying them to the sound device. It actually works quite well.
    While a WAV file can contain a lot of additional information, most files don't. And a 44kbit/s 16-bit stereo file normally has a 44-byte header. Each audio sample corresponds to 4 bytes. So the header represents 11 audio samples which is 11/44100 = 249 us of noise. With 16-bit 11kbit/s mono, you get about 2ms of noise. Lots of - if not most - embedded equipment that plays sound produces way more "click" sound from turning on the amplifier than the noise created from playing the header.
    In the end, a teacher is not likely to notice a project where the student goes the easy route and plays the header too.
  • If you have downloaded the legacy pack from keil.com/mdk5 (click the link in the gray box on the top right of the screen, and download the arm7/9 example
    Once you have the pack, take a look at this example which converts wavs into something that can be loaded onto a board
    C:\Keil_v5\ARM\Boards\Keil\MCB2130\VoicePlayer\
    The WAVs are in the audiodata folder
