Hello, I have a project in IAR where is .def file and I need this project in Keil. So I am importinr file by file but the only problem is how to import .def. When I import this file it ask me to choose file format (C, Image, Object file....etc.). I have tried to save it as all posible formats but i still have problem when i want to build it. It always gives me an error message : "type of imput file "types.def" unknown". Does anyone know how to add the file .def correctly?
Thanks in advance
Jan
Why do you want to import the *.def file, when Keil obviously doesn't support any such file?
Your goal should be to instead consider the contents of the *.def file and then see whatever similar functionality Keil has.
