I need to compile firmware on a single machine using multiple versions of Keil uVision 4.60.6.8 and 4.72.9.0. From a configuration management perspective the best solution is to store both versions in a code repository so that the products will be reproducible for the foreseeable future. I am unable to find support on how to run uVision from a file set. When I say run uVision from a file set I intend on having the build process access the compiler and use the installed license on the machine.
Thank You for your help!
JP
