Keil µVision 4.x PK166 on Windows Server
Hi there,
we are using Keil µVision 4 PK166 with XE16x Microcontrollers
does anyone know, if the installation and usage of Keil µVision 4.x is generally supported and possible on Windows Server x64?
The main point is, if licensing and the compiler are working in order to compile source code on the server.
Thanks in advance!
  • Maybe you should add some information about if it just happens to be a server license, or if the installation is intended for multiple users.
    And another note - this is an end-user forum. So it's best to communicate directly with Keil support. You can find contact links at the top and botton of all pages.
