I have a project that uses RTX and Keil middle-ware running on a NXP 43xx processor. I have recently changed the compiler settings from C to C++ due to incorporating a commercial library that is written in C++. The project now complies and runs property but now no RTX task information is displayed in the uVision debugger “System and Thread Viewer” window.
To remove compiler errors I had to modify all of the global variable definitions in the library interface modules, RTX_lib.c, Net_lib.c and File_lib.c as in this example:
Original definition
U32 const os_trv = OS_TRV;
Modified definition
#ifdef __cplusplus extern "C" U32 const os_trv = OS_TRV; #else // CHRISB U32 const os_trv = OS_TRV; #endif
Originally I was using uVision v4.72 then upgraded to uVision v5.13 with legacy support. Both compiler versions have the same problem of not showing task information. I have double checked all of the project settings and other than “—cpp” compiler directive everything is the same.
Any help would be appreciated. Thanks
