USB in DMA mode
Hi every body
I want to get data from PC and store in arm memory and after process sent by ssp.
I use usb_cdc mode and i can't initialize usb in DMA mode.
I use uvision 5 and the project is here:
Download:
www.transferbigfiles.com/.../9MUgnGGqw9o8a39vyHIdUA2
  • i can't initialize usb in DMA mode.
    For LPC1768, you may find USB DMA setup in usbhw.c of USBCDC example on this code bundle.
    MCB1700 Sample Code Bundle for LPC17xx Peripherals using Keil's MDK-ARM
    www.lpcware.com/.../mcb1700-sample-code-bundle-lpc17xx-peripherals-using-keils-mdk-arm
    Find "#if USB_DMA" on usbhw.c
    Tsuneo
  • Thanks Dear Tsuneo Chinzei
    I have some question:
    1- I want to send data from PC via usb (cdc_mode) 64Byte packet to hardware, witch endpoint i should enable? out or in (I use EP2 and set endpoint 2 out)
    This parameter is set in usbcfg.h :
    #define USB_POWER 0
    #define USB_IF_NUM 4
    #define USB_EP_NUM 32
    #define USB_MAX_PACKET0 64
    #define USB_DMA 1
    #define USB_DMA_EP 0x00000010
    2- I use the code below in USB_EndPoint2 (uint32_t event) and always the first event is "USB_EVT_OUT_DMA_ERR" what is the reason?
    if (event == USB_EVT_OUT_DMA_EOT) { /* End of Transfer */
    } if((event == USB_EVT_OUT_DMA_ERR)||(event == USB_EVT_OUT_NAK)) {
    } if (event & USB_EVT_IN_DMA_NDR) { DD.BufAdr = (uint32_t)DataBuf ; //+ DataIn; /* DMA Buffer Address */ DD.BufLen = 64; /* DMA Packet Count */ DD.MaxSize = 64; /* Must be 0 for Iso Transfer */ DD.InfoAdr = (uint32_t)InfoBuf; /* Packet Info Buffer Address */ DD.Cfg.Val = 0; /* Initial DMA Configuration */ DD.Cfg.Type.IsoEP = 0; /* Iso Endpoint */ DD.Cfg.Type.ATLE = 0; /* Iso Endpoint */ DD.Cfg.Type.Link = 0; USB_DMA_Setup(0x02, &DD); /* Setup DMA */ USB_DMA_Enable(0x02); /* Enable DMA */ LPC_USB->USBDMARSet |= 0x20; }
    3- Is USBDMARSet set correct?
    Thanks a lot.
  • > 1- I want to send data from PC via usb (cdc_mode) 64Byte packet to hardware, witch endpoint i should enable? out or in (I use EP2 and set endpoint 2 out)
    As USB is host-centric,
    OUT: host -> device
    IN: device -> host
    OUT EP2 (logical) = physical EP 4
    "#define USB_DMA_EP 0x00000010" is right definition for this endpoint.
    The first "event" of this OUT EP should be NDDR (USB_EVT_OUT_DMA_NDR)
    But your code assigns "USB_EVT_IN_DMA_NDR" case to it. Replace "IN" to "OUT"
    Also, "LPC_USB->USBDMARSet |= 0x20;" is not required for the OUT endpoint.
    Tsuneo
