The following code, simple as it is, fails to work. I suspect it's a brain short on my part, and willingly accept the public humiliation. Perhaps it's an actual problem that I am just now uncovering. I am new to the toolset, so all bets are off. The tool is a bit on the dated side. Perhaps there is an update that I'm missing.
TIA for any help.
John
IDE-Version: µVision V4.72.10.0 Copyright (C) 2013 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: MDK-ARM Standard Cortex-M only Version: 4.72.1.0 Toolchain Path: C:\Keil\ARM\ARMCC\bin\ C Compiler: Armcc.Exe V5.03.0.76 Assembler: Armasm.Exe V5.03.0.76 Linker/Locator: ArmLink.Exe V5.03.0.76 Librarian: ArmAr.Exe V5.03.0.76 Hex Converter: FromElf.Exe V5.03.0.76 CPU DLL: SARMCM3.DLL V4.72.1.0 Dialog DLL: DARMP1.DLL V1.22.0.11 Target DLL: UL2CM3.DLL V1.150.11.0 Dialog DLL: TARMP1.DLL V1.22.0.11
float gain; float fTemp; uint32_t lTemp; uint16_t temp; // On entry, gain is 27.893 fTemp = gain * 1000.0; // gain - preserve three decimal places // fTemp now 27893.0 lTemp = (uint32_t)fTemp; // lTemp now 0x6C5F (27743, while I expect 27893) temp = lTemp & 0xFFFF; // temp now 27743 // WTH?
