Interfacing Seven Segment Display.
Hi all..
I am trying to interface keypad and Seven Segment display with 89S52.
what i need to do is whatever keys are pressed from keypad, it should show on seven segment display. for Eg. if 2 is pressed from keypad then display should show 2. and so on.
my code is...
#include<reg51.h>
#include<stdio.h>
sbit row0=P2^7; //assigning PORT-0 to read rows
sbit row1=P2^6; //assigning PORT-0 to read rows
sbit row2=P2^5; //assigning PORT-0 to read rows
sbit row3=P2^4; //assigning PORT-0 to read rows
sfr COL=0xA0;   //assigning PORT-2 to read colomns
sbit buz=P3^2;
sbit seg0=P3^0;
sbit seg1=P3^1;
sbit seg2=P3^2;
sbit seg3=P3^3;
sbit seg4=P3^4;
sbit seg5=P3^5;
void msdelay(unsigned int value);
int keypad();
char digi[10]={0x40,0xF9,0x24,0x30,0x19,0x12,0x02,0xF8,0x00,0x10};
unsigned char numbers[6]={"44444"};
void main()
unsigned int i;
while(1)
   do
    numbers[i]=keypad();
    i++;
   while(i!=6);
   i=0;
     P1=0x40;
}                       // MAIN ENDS HERE.
 unsigned int i,j;
 for(i=0;i<value;i++)
 for(j=0;j<100;j++);
int keypad()
        unsigned char dat[4][4]={'7','8','9','A',        // assigning key matrix
                                 '4','5','6','B',
                                 '1','2','3','-',
                                 '*','0','#','+',};
 unsigned char colloc,rowloc;
 COL=0x0F;
 row0=0;
 row1=0;
 row2=0;
 row3=0;
 while(1)
  do
    do
      msdelay(90);
      colloc=COL;
      colloc&=0x0F;
   while(colloc==0x0F);
   msdelay(90);
   colloc=COL;
   colloc&=0x0F;
  while(1)
        row0=0;
        row1=1;
        row2=1;
        row3=1;
        msdelay(5);
        colloc=COL;
        colloc&=0x0F;
        if(colloc!=0x0F)
         rowloc=0;
         break;
         row0=1;
         row1=0;
         row2=1;
         row3=1;
         msdelay(5);
         colloc=COL;
         colloc&=0x0F;
         if(colloc!=0x0F)
          rowloc=1;
          break;
         row0=1;
         row1=1;
         row2=0;
         row3=1;
         msdelay(5);
         colloc=COL;
         colloc&=0x0F;
         if(colloc!=0x0F)
           rowloc=2;
           break;
        row0=1;
        row1=1;
        row2=1;
        row3=0;
        msdelay(5);
        colloc=COL;
        colloc&=0x0F;
        if(colloc!=0x0F)
         rowloc=3;
         break;
if(colloc==0x0E)
  return(dat[rowloc][0]);
else if(colloc==0x0D)
  return(dat[rowloc][1]);
else if(colloc==0x0B)
  return(dat[rowloc][2]);
else
  return(dat[rowloc][3]);
i have not tried anything because i am not getting any idea of how to start with...
because the output from keypad i get is numbers. and to display on seven segment we need hex.
how can i do this.
in my code, in MAIN function i have just tried to save the numbers from what i get from keypad to array numbers[7].
seven segment display are common anode and are connected to port 1 of 89S52.
0
