hi to all, i am new in mdk5 and i working on a project that in it i need to communicate through usart of my micro, i want to use from cmsis::usart lib to access usart. when i read the documentation of cmsis i found below example
#include "Driver_USART.h" #include "cmsis_os.h" /* ARM::CMSIS:RTOS:Keil RTX */ #include <stdio.h> #include <string.h> void myUART_Thread(void const *argument); osThreadId tid_myUART_Thread; /* USART Driver */ extern ARM_DRIVER_USART Driver_USART3; void myUSART_callback(uint32_t event) { switch (event) { case ARM_USART_EVENT_RECEIVE_COMPLETE: case ARM_USART_EVENT_TRANSFER_COMPLETE: case ARM_USART_EVENT_SEND_COMPLETE: case ARM_USART_EVENT_TX_COMPLETE: /* Success: Wakeup Thread */ osSignalSet(tid_myUART_Thread, 0x01); break; case ARM_USART_EVENT_RX_TIMEOUT: __breakpoint(0); /* Error: Call debugger or replace with custom error handling */ break; case ARM_USART_EVENT_RX_OVERFLOW: case ARM_USART_EVENT_TX_UNDERFLOW: __breakpoint(0); /* Error: Call debugger or replace with custom error handling */ break; } } /* CMSIS-RTOS Thread - UART command thread */ void myUART_Thread(const void* args) { static ARM_DRIVER_USART * USARTdrv = &Driver_USART3; ARM_DRIVER_VERSION version; ARM_USART_CAPABILITIES drv_capabilities; char cmd; #ifdef DEBUG version = USARTdrv->GetVersion(); if (version.api < 0x200) /* requires at minimum API version 2.00 or higher */ { /* error handling */ return; } drv_capabilities = USARTdrv->GetCapabilities(); if (drv_capabilities.event_tx_complete == 0) { /* error handling */ return; } #endif /*Initialize the USART driver */ USARTdrv->Initialize(myUSART_callback); /*Power up the USART peripheral */ USARTdrv->PowerControl(ARM_POWER_FULL); /*Configure the USART to 4800 Bits/sec */ USARTdrv->Control(ARM_USART_MODE_ASYNCHRONOUS | ARM_USART_DATA_BITS_8 | ARM_USART_PARITY_NONE | ARM_USART_STOP_BITS_1 | ARM_USART_FLOW_CONTROL_NONE, 4800); /* Enable Receiver and Transmitter lines */ USARTdrv->Control (ARM_USART_CONTROL_TX, 1); USARTdrv->Control (ARM_USART_CONTROL_RX, 1); USARTdrv->Send("\nPress Enter to receive a message", 34); osSignalWait(0x01, osWaitForever); while (1) { USARTdrv->Receive(&cmd, 1); /* Get byte from UART */ osSignalWait(0x01, osWaitForever); if (cmd == 13) /* CR, send greeting */ { USARTdrv->Send("\nHello World!", 12); osSignalWait(0x01, osWaitForever); } } }
i am ok with that but i can not undrestand one thing, my micro has 4 usart port, how i can indicate that i want to use for example usart3 of my micor.
Mean that by appending number to name instance of driver we can indicate our purpose uart number??
It means that every UART has has a struct overlaying the registers of the UART.
So Driver_USART3 happens to be a struct overlaying the registers for UART3. And USARTdrv will then be a pointer that points to the registers of UART3 and so will perform all actions on that UART.
got it, thanks ;)
