hello Keil still I donot understand why I should initialize array passed to function inside that function although it is completed in calling function
ex like this part if i make line ExprTokens[TOKEN_NUM-1][TOKEN_LEN-1]=0; then every thing ok and if omitted then program hang in communation part with SD ( sd rx buffer problem)
double ExprEvaluation( char ExprTokens[TOKEN_NUM][TOKEN_LEN],char Tkn) { uint8_t i,j,k; double t0,t1,t2,t3; ExprTokens[TOKEN_NUM-1][TOKEN_LEN-1]=0; // if not exist cause browser hang ...
thanks in advance
