Hello, I am using MDK5. While using the HTTP server sample code the driver code which is already included is not required.Because I am using a different ethernet driver. I have written code for my driver. But due to the older file error .\Output\HTTP_Server.axf: Error: L6200E: Symbol Driver_ETH_PHY0 multiply defined (by phy_dp83848c.o and phy_dp83640.o). is occuring. Inviting your valuable suggestions.
you can deselect these PHY drivers from the HTTP server sample project in "Manage Run-Time Environment"
