Hi, I used uVersion4 and got the following message: Program Size: data=62.2 xdata=0 code=2533 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S) *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: J:\PROGRAM FILES\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 0800H BYTES Target not created
What can I do ?
1 - Pay for a full licence 2 - Reduce the code size so it fits inside the evaluation limit 3 - Consider an alternative package 4 - Panic
5 switch to a SILabs chip
All that said, I'd rather try to find a way to switch to a small ARM Cortex cored part.
I'm a proud convert.
