I have a STM32F411RE Nucleo board. I can compile and run the 'Blink-LED' program just fine on mbed. I'm trying out 'free version' of uVision 5.13. When I export the 'Blink-LED' program and try to compile it in uVision, I get the following errors:
Build target 'mbed NUCLEO_F411RE' compiling main.cpp... Error: C9511E: Product definition file was not found. The following paths were searched: - C:\Keil_v5\ARM\ARMCC\Bin\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\sw\mappings\mdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:\Keil_v5\ARM\ARMCC\sw\mappings\armcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 1 (build 106) Tool: ArmCC [4d0efa] linking... .\build\Nucleo_blink_led.axf: Error: L9511E: Product definition file was not found. The following paths were searched: - C:\Keil_v5\ARM\ARMCC\Bin\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\sw\mappings\mdk_cm_pro.elmap .\build\Nucleo_blink_led.axf: Error: L9545E: Info key CT.ProductName could not be found in product definition C:\Keil_v5\ARM\ARMCC\sw\mappings\armcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 1 (build 106) Tool: armlink [4d0efa] Finished: 1 information, 0 warning and 2 error messages. ".\build\Nucleo_blink_led.axf" - 2 Error(s), 0 Warning(s). Target not created.
I have the following 'packs' installed: ARM::CMSIS Keil:: MDK-Middleware Keil::STM32F4xx_DFP Keil::STM32NUCLEO_BSP
If someone could point me in the right direction, I'd greatly appreciate it.
Thanks, Duane
If you feel that the chip is not currently/yet supported, I'd suggest you contact Keil Support directly and discuss it with them.
