Hello,guys, i need the Intel HEX to BINARY File Converter and BINARY to Intel HEX Converter Utility in some C51 based Project,and i found the below 2 links: http://www.keil.com/download/docs/113.asp http://www.keil.com/download/docs/7.asp
then i check www.hex2bin.com/.../ and www.hex2bin.com/.../,but they are all not available for me,may be it is not available anymore? is there someone has saved these 2 Converter Utility locally? would you pls help to send me a copy?my email is guitarbug#gmail.com(pls replace # with @) Thank you!
BR Frank
bin2hex.exe you can load from many locations in internet ... .
thanks for the reply.Yes,you are right.
BUT our project need the option </4 Generate HEX file using ext. linear address records (HEX386)> of BIN2HEX to convert BIN to HEX.
and need the below options of HEX2BIN to convert HEX to BIN /Ln Bytes to read from binary file /On Output file address offset (where HEX data starts) /M Merge data into existing HEX file
srec_cat at
srecord.sourceforge.net/
like: srec_cat file.bin -binary -offset 0x90000000 -o file.hex -intel
John has sent it to me,thanks. closing this thread.
