I am trying to integrate SDcard on to my project. My basic Aim is to transfer files to SDcard. The files are nearly 5MB to 10 MB in size. I used NSK electronics LPC 2148 development board. There are some sample SD card programs given. I compiled the code. The SD card initialization was unsuccessful. The sd_initinialize() function has two conditions : sd_init() and sd_state() is returning is returning a negative value, which means that the SD card is not initialized.
The LCD shows "SD CARD - not OK" I crossed checked the PIN configuration and spisend() function check, but i still couldn't figure what is wrong ?
Source code for main.c
#include <LPC214X.H> #include "lcd.h" #include "type.h" #include "types.h" #include "lpc2000_spi.h" //#include "ssp.h" //void delay(unsigned long int count1); void wait (void); U8 init_sdcard(void); int main (void) { unsigned char i; unsigned status; unsigned char SDCheckFlag; lcd_init(); { lcd_write_control(0x01); goto_cursor(0x00); if(init_sdcard()) { lcd_print("SD card - OK"); SDCheckFlag = 1; } //else if(init_sdcard() == -1) //{ // lcd_print("SD Card-error = -1"); //} //else if(init_sdcard() == -2) //{ // lcd_print("SD Card-error = -2"); //} else { lcd_print("SD card - not OK"); SDCheckFlag = 0; } delay(100000); } }
Source Code for lpc2000_sd.c
#include <LPC214x.H> /* LPC214x definitions */ #include "lpc2000_spi.h" #include "sd.h" #include "type.h" #include "ssp.h" #include "utils.h" #define SD_CARD BIT20 #define SD_SELECTION_DIR_SET (IO0DIR |= SD_CARD) #define SD_SELECTION_SET (IO0SET = SD_CARD) #define SD_SELECTION_CLR (IO0CLR = SD_CARD) esint8 if_initInterface(eint8* opts) { if_spiInit(); if(sd_Init()<0) { DBG((TXT("Card failed to init, breaking up...\n"))); return(-1); } if(sd_State()<0) { DBG((TXT("Card didn't return the ready state, breaking up...\n"))); return(-2); } // file->sectorCount=4; /* FIXME ASAP!! */ // DBG((TXT("Init done...\n"))); else return(0); } euint8 if_spiSend(euint8 outgoing) { euint8 incoming=0; while ( !(SSPSR & SSPSR_TNF) ); SSPDR = outgoing; while (!(SSPSR & SSPSR_RNE)); incoming = SSPDR; return(incoming); } void if_spiInit() { spi1_init(); SD_SELECTION_DIR_SET; SD_SELECTION_CLR; } #if 0 esint8 if_readBuf(hwInterface* file,euint32 address,euint8* buf) { return(sd_readSector(file,address,buf,512)); } esint8 if_writeBuf(hwInterface* file,euint32 address,euint8* buf) { return(sd_writeSector(file,address, buf)); } #endif
Sorry, the code you have presented doesn't seem remotely helpful for debugging the problem.
Got an oscilloscope or logic analyzer? Inspect with them. Review documentation on card signalling and command protocols.
How big are the cards? SDHC cards behave in a materially different way than 2GB SD cards, or older MMC cards.
Does NSK provide free or paid support for their product?
