case ARM_I2C_BUS_SPEED: pclk = HAL_RCC_GetPCLK1Freq(); switch (arg) { case ARM_I2C_BUS_SPEED_STANDARD: /* Clock = 100kHz, Rise Time = 1000ns */ if (pclk > 50000000U) { return ARM_DRIVER_ERROR_UNSUPPORTED; } if (pclk < 2000000U) { return ARM_DRIVER_ERROR_UNSUPPORTED; } ccr = (pclk / 100000U) / 2U; trise = (pclk / 1000000U) + 1U; break; case ARM_I2C_BUS_SPEED_FAST: /* Clock = 400kHz, Rise Time = 300ns */ if (pclk > 50000000U) { return ARM_DRIVER_ERROR_UNSUPPORTED; } if (pclk < 4000000U) { return ARM_DRIVER_ERROR_UNSUPPORTED; } if ((pclk >= 10000000U) && ((pclk % 10000000U) == 0U)) { ccr = I2C_CCR_FS | I2C_CCR_DUTY | ((pclk / 400000U) / 25U); } else { ccr = I2C_CCR_FS | ((pclk / 400000U) / 3U); } trise = (pclk / 333333U) + 1U; break; default: return ARM_DRIVER_ERROR_UNSUPPORTED; } i2c->reg->CR1 &= ~I2C_CR1_PE; /* Disable I2C peripheral */ i2c->reg->CR2 &= ~I2C_CR2_FREQ; i2c->reg->CR2 |= pclk / 1000000U; i2c->reg->CCR = ccr; i2c->reg->TRISE = trise;
if pclk is 42MHz, trise is 127, but i2c->reg->TRISE is 6bits register.
