profiling problem
hi
am trying to profile my code however when i enable "show time" and the "Performance Analyzer
" i remarked that the keil didn't run the main.c since there is no time displayed neither on the left of the sources console nor on performance analyser console
so i wonder is there some conditions related to the source file since my friend who has an other code managed to get the execution time of her main.c
by the way my code define some struct to calculate the energy, ETX ,position ..of nodes in a wireless Sensors Networks
thank you
  • In order to use "Performance Analyzer", you have to have a debugger that fully supports instruction trace, such as ULINKpro. And you should enable the ETM trace and configure the trace port correctly.
    More details: www.keil.com/.../uv4_db_dbg_perfanalyzer.htm
  • thank you for your reply
    however i don't know how to define the trace port moreover i get this message
    No Ulink device found
  • Do you have a ULINK or ULINKPro, and is it connected?
    The Pro will need a high quality USB cable, I've seen connection issues without one.
  • well
    I don't have a ULINKPro, I just got carried away and tried to follow instructions before going back to the tutorial and do my research.
    I can't do a hardware debugging so i will limit myself with the simulator.
    however am wondering if the results displayed by the performance analyser,using the simulator, are accurate or at least a bit close to those performed by the Cortex m-0
    (am talking about my friend since i didn't get any result)
  • The results should be reasonable - the main difference would probably be unexpected pipe stalls depending on number of cycles required to fetch new code or read/write to RAM. Keil will not know the exact behavior of the data paths of your specific chip.
  • thank you Mr Per Westermark i was worried since my PC' processor has a CISC architecture and as you know the Cortex m-0 is a RISC one
    So i was afraid that the profiling was done by my PC'processor (as in code blocks) and not by simulating the behavior of the Cortex m-0
    so let's return to my original problem
    why the keil doesn't execute the main.c it only displays the execution time of my cm0dsasm.s :
    Stack_Size      EQU     0x00000400                                                      ; 256KB of STACK
                    AREA    STACK, NOINIT, READWRITE, ALIGN=4
    Stack_Mem       SPACE   Stack_Size
    __initial_sp
    Heap_Size       EQU     0x00000400                                                      ; 1MB of HEAP
                    AREA    HEAP, NOINIT, READWRITE, ALIGN=4
    __heap_base
    Heap_Mem        SPACE   Heap_Size
    __heap_limit
    ; Vector Table Mapped to Address 0 at Reset
                                                    PRESERVE8
                                    THUMB
                                            AREA    RESET, DATA, READONLY
                                            EXPORT  __Vectors
    __Vectors                       DCD             0x0000FFFC
                                            DCD             Reset_Handler
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD     0
                                            DCD             0
                                            DCD             0
                                            DCD     0
                                            DCD             0
                                            ; External Interrupts
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                                            DCD             0
                    AREA |.text|, CODE, READONLY
    ;Reset Handler
    Reset_Handler   PROC
                    GLOBAL Reset_Handler
                    ENTRY
                                    IMPORT  __main
                    LDR     R0, =__main
                    BX      R0                        ;Branch to __main
                    ENDP
                                    ALIGN           4                                        ; Align to a word boundary
    ; User Initial Stack & Heap
                    IF      :DEF:__MICROLIB
                    EXPORT  __initial_sp
                    EXPORT  __heap_base
                    EXPORT  __heap_limit
                    ELSE
                    IMPORT  __use_two_region_memory
                    EXPORT  __user_initial_stackheap
                    LDR     R0, =  Heap_Mem
                    LDR     R1, =(Stack_Mem + Stack_Size)
                    LDR     R2, = (Heap_Mem +  Heap_Size)
                    LDR     R3, = Stack_Mem
                    BX      LR
                    ALIGN
                    ENDIF
                    END
    however my friend use the same assembly file and the keil execute her c code ,which is different than mine (i define some struct but she doesn't) ,so i was wondering if the prob is within my c codes or something else .
    thanks for your collaboration
