I want to simulate an external pulse arriving to an input pin on my LPC1778 using Keil.
I have written the following code:
SIGNAL void GPIO_Test_Pulse (void) { int j; PORT4 = 0x0; while (1) { PORT4 |= (1 << 18); // set pin 0.18 swatch (0.001); //1ms //j= ((PORT4 >> 18) & 1); PORT4 &= ~(1 << 18); // reset pin 0.18 swatch (0.001); //1ms //j= ((PORT4 >> 18) & 1); } }
I have configured pin 18 of port 4 as an output(GPIO). There are 2 concerns: 1. How do you add just the pin of interest to the logic analyser and not the entire PORT? Logic analysers are able to only probe global variables.If so, how do i add variable 'j' in my code to the logic analyser? 2.This pulse should be made as input to port 1 pin 1(which is configured as input GPIO).What addition code must i add to make this available as input to port 1 pin 1?
Where am i going wrong?
